Merge to email using only Outlook
› Developer › Merge to email using only Outlook
Last reviewed on September 2, 2014     5 Comments
Over the last several weeks, several people asked if they could do a mail merge from Contacts to Outlook email directly. Yes, it is possible to insert contact data into an email message, merge style, although it's generally easier to merge to email using Microsoft Word's Mail Merge.
Your options are:
Use VBA to start a new email message and insert contact fields into the message. This works great for the subject field (and the To field). If you are inserting contact fields into the body, it works best if the message is short or the contact fields are added to the top of the message body. The deferred birthday greeting to contact code sample uses this method.
Create a template with bookmarks for the fields you want to use. The code sample below uses this method to merge a contact's data to a new message.
This screenshot shows the template and the merged email message.
email merge contact
Mail merge code sample
To use this code:
  1. Set macro security to low for testing.
  2. Download the template.
  3. Copy and paste the code into the VBA editor.
  4. Set a reference to Word object model in the VB Editor's Tools, References menu
  5. Make sure the path to the template is correct in the code.
  6. Select a contact in Outlook and run the macro.
Public Sub MailMergeNoWord()
If TypeName(ActiveExplorer.Selection.Item(1)) = "ContactItem" Then
 Set oContact = ActiveExplorer.Selection.Item(1)
Dim objItem As MailItem
Set objItem = Application.CreateItemFromTemplate("C:\path\to\template\bookmark-test.oft")
With objItem
   .To = oContact.Email1Address
   .Subject = "This is the subject"
  ' send from another address; sendas permission required
   .SentOnBehalfOfName = "sales@domain.com"
   .Display
End with
'after the message is open and addressed to the contact, use reference word to put fields into bookmarks
    Dim objDoc As Word.Document
    Dim objSel As Word.Selection
'Set objItem = Application.ActiveInspector.CurrentItem
        If objItem.Class = olMail Then
            Set objInsp = objItem.GetInspector
       'create a bookmark, repeat these two lines for each bookmark
        objSel.GoTo What:=wdGoToBookmark, Name:="name"
        objSel.TypeText Text:=oContact.FirstName
        objSel.GoTo What:=wdGoToBookmark, Name:="fullname"
        objSel.TypeText Text:=oContact.FirstName & " " & oContact.LastName
        objSel.GoTo What:=wdGoToBookmark, Name:="email"
        objSel.TypeText Text:=oContact.Email1Address
        objSel.GoTo What:=wdGoToBookmark, Name:="company"
        objSel.TypeText Text:=oContact.CompanyName
MsgBox "Sorry, you need to select a contact"
    Set objItem = Nothing
    Set objSel = Nothing
    Set objWord = Nothing
    Set objInsp = Nothing
Merge to email using only Outlook was last modified: September 2nd, 2014 by Diane Poremsky
  • How to replicate Outlook's New letter to Contact feature using a custo
    Create a Letter to a Contact using VBA
  • Mail Merge to Email using an Outlook Macro
  • Use Word Macro to Apply Formatting to Email
  • Mail merge and Send from a Distribution Group
  1. Jason says
    July 16, 2014 at 1:51 am
    can you do the same and pull data from an external database (e.g. excel file)?
      July 16, 2014 at 3:53 pm
      You can use an external database in a mailmerge, either using the built in mail merge function in Word or using a macro. I don't have any macro examples that use Excel data in a merge though.
  2. Trevor says
    May 20, 2013 at 5:43 am
    yes ocontact.UserProperties (“custom”) was the correct function. Thanks
  3. Crista says
    May 16, 2013 at 8:00 am
    Thank you for this post, what is the code to pull a custom field. I tried:
    objSel.GoTo What:=wdGoToBookmark, Name:="custom"
    objSel.TypeText Text:=oContact.Find("custom")
    But that did not work. I know I am missing something simple here.
    -Trevor
      May 17, 2013 at 6:22 pm
      In VBA you need to use userproperties, try ocontact.UserProperties ("custom") - I'm not quite sure if that is the correct syntax but don't have time to verify it right now.
Latest EMO: Vol. 31 Issue 5
