Could not complete the operation. One or more parameter values are not valid.
› Problems › Could not complete the operation. One or more parameter values are not valid.
Last reviewed on June 28, 2016     24 Comments
Applies to: Outlook 2010
When you receive this error message:
while addressing or sending an email message, meeting request, or assigning a task, or saving a new contact, your auto-complete list may be corrupt. Some users also report getting this error when they save an appointment or task.
The solution: clear the auto-complete list cache.
Outlook 2010: Clear Names from the Auto-Complete List
To remove single addresses, select the name using the arrow keys then press Delete. In Outlook 2010, you can also click the x beside the name to delete it or use the Backspace key.
In Outlook 2010, you can clear the cache using the File, Options, Mail dialog, Empty Auto-complete List button.
Empty Autocomplete cache
You can also close Outlook and use the /cleanautocompletecache startup switch. To use, press Windows key + R to open the run command then paste
outlook.exe /cleanautocompletecache
in the Open field and press OK.
Outlook 2007 and Outlook 2003
To remove single addresses from the list in Outlook 2007 or Outlook 2003, select the name using the arrow keys then press Delete.
In Outlook 2007 and Outlook 2003, you can remove all of the addresses from the autocomplete cache, either by deleting the NK2 file (at %USERPROFILE%\Application Data\Microsoft\Outlook ) or by opening Tools, Options, Email Options, Advanced Email Options and deselecting the option to suggest names near the bottom of the dialog.
For a list of utilities you can use to edit the auto-complete cache, see Understanding Outlook’s Auto-Complete Cache (*.NK2)
Could not complete the operation. One or more parameter values are not valid. was last modified: June 28th, 2016 by Diane Poremsky
  • Moving Outlook's auto-complete address list to a new account
  • Understanding Outlook's AutoComplete Cache
  • Outlook Contacts, Address Book, and Autocomplete
Subscribe
Notify of
24 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Atul
December 8, 2021 5:17 am
Thank you Diane, it worked for me. I tried all other options but it was your which finally solved the issue after almost 2 hrs of trying. Even my IT Personnel could not help :)
0
0
Ginka
May 19, 2017 11:14 am
I get this message when I try to print a message.
0
0
Author
Reply to  Ginka
May 19, 2017 2:36 pm
Find and delete outlprnt. it's at %appdata%microsoftoutlook
0
0
Anna
January 9, 2017 9:17 am
Thank you Diane! It really worked!
0
0
kristen
June 27, 2016 2:17 pm
What do you do if it says that "received field is not valid"
0
0
Author
Reply to  kristen
June 28, 2016 11:46 pm
I would try clearing the autocomplete cache.
0
0
Nelson
June 6, 2014 7:01 pm
I have a problem where the tasks do not appear in the To Do Bar. I tried /resettodobar on startup and nothing. Also /resetnavpane with similar results.
0
0
Reply to  Nelson
June 7, 2014 12:40 am
Do you have any filters set? What do you see where tasks should be?
0
0
Mark
October 3, 2013 6:05 am
They are opening a message they have received then entering a name in the To: field. After that they try to move the message to another folder and get the error.
0
0
Mark
October 2, 2013 8:00 am
My users get this error when doing a very specific process in Outlook 2010 on Win7.
Open an email they have received.
Enter a name in the To: field
Move the email to another folder.
Apparently this works in Outlook 2007 but they are running XP (if that makes any difference).
0
0
Reply to  Mark
October 2, 2013 12:55 pm
I don't think the Windows version matters. Are they adding names to the To field of Draft messages or of messages they received?
1
-1
heha Ha
September 28, 2013 8:34 am
I face this problem today when sync my hotmail a/c on Outlook 2003 with server (MAPI connection). All folders cannot be sync.
By same Outlook profile, I have another Live email account (also MAPI connection). There is no problem on sync between client side and server.
When lead to problem and how to solve? Please advise
1
-1
Reply to  heha Ha
September 28, 2013 8:23 pm
Do you get any error messages in Outlook 2003? Look in the sync error folders and see if any of the messages hold clues.
1
-1
Latest EMO: Vol. 30 Issue 29
  • New Outlook: Show To, CC, BCC in Replies
  • Insert Word Document into Email using VBA
  • Delete Empty Folders using PowerShell
  • Warn Before Deleting a Contact
wpDiscuz
Never see this message again.
Move Comment
