Use the following VBA code to create a contact picker. You can change the code to allow for a manual pick of contacts folder, ie not hardcoded. If you have contacts stored in another folder, this change will make it easier to use.
Sub ReconnectLinks()
Dim objApp As Application
Dim objNS As NameSpace
Dim objFolder As MAPIFolder
Dim colItems As Items
Dim objItem As Object
Dim colLinks As Links
Dim objLink As Link
Dim colContacts As Items
Dim objContact As ContactItem
Dim strFind As String
Dim intCount As Integer
Dim myFolder1 As MAPIFolder
Set objApp = CreateObject("Outlook.Application")
Set objNS = objApp.GetNamespace("MAPI")
'set contacts folder
Set myFolder1 = objNS.PickFolder
'set tasks folder
Set objFolder = objNS.PickFolder
If TypeName(objFolder) <> "Nothing" Then
'Set colContacts = objNS.GetDefaultFolder(olFolderContacts).Items
Set colContacts = myFolder1.Items
Set colItems = objFolder.Items
For Each objItem In colItems
Set colLinks = objItem.Links
intCount = colLinks.Count
If intCount > 0 Then
For i = intCount To 1 Step -1
Set objLink = colLinks.Item(i)
If objLink.Item Is Nothing Then
strFind = "[FullName] = " & AddQuotes(objLink.Name)
Set objContact = colContacts.Find(strFind)
If Not objContact Is Nothing Then
' remove the old link
colLinks.Remove i
' add the replacement link
colLinks.Add objContact
If Not objItem.Saved Then
objItem.Save
Set objLink = Nothing
Set colLinks = Nothing
Set objItem = Nothing
Set objItems = Nothing
Set objFolder = Nothing
Set objNS = Nothing
Set objApp = Nothing
Private Function AddQuotes(MyText) As String
AddQuotes = Chr(34) & MyText & Chr(34)
End Function
