Applies to Microsoft Outlook 2010, Outlook 2007, Outlook 2003, Outlook 2002, Outlook 2000
In Outlook SecureTemp Files Folder and Red X's in Email Messages I explain what the SecureTemp folder is and issues that result from a "full" SecureTemp folder. I also tell you how to find the folder and empty it manually.
While you can delete the contents of the SecureTempFolder manually, you may want to delete the folder each time you close Outlook.
If you prefer to run this manually whenever you feel like it, change Private Sub Application_Quit() to Public Sub EmptySecureTemp() and run it as needed.
To use, open the VBA editor using Alt+F11 then add the code to ThisOutlookSession.
Reprinted with permission of Peter Marchert
Option Explicit
' Deletes the files of the SecureTempFolder (OLK) when closing Outlook
' (c) Peter Marchert - http://www.outlook-stuff.com
' 2008-11-06 Version 1.0.0
Dim objFSO As Object
Dim objWsh As Object
Dim objFolder As Object
Dim strRegKey As String
Dim strOLK As String
' To read data from the registry
Set objWsh = CreateObject("WScript.Shell")
' Set the registry key to read
strRegKey = "HKCU\Software\Microsoft\Office\%.0\Outlook\Security\OutlookSecureTempFolder"
' Read SecureTempFolder from the registry
Select Case Left(Outlook.Version, 2)
Case "9.": strOLK = objWsh.RegRead(Replace(strRegKey, "%", "9"))
Case "10": strOLK = objWsh.RegRead(Replace(strRegKey, "%", "10"))
Case "11": strOLK = objWsh.RegRead(Replace(strRegKey, "%", "11"))
Case "12": strOLK = objWsh.RegRead(Replace(strRegKey, "%", "12"))
Case "14": strOLK = objWsh.RegRead(Replace(strRegKey, "%", "14"))
Case Else
MsgBox "Cannot determine your Outlook version.", vbCritical + _
vbOKOnly, "Delete OLK"
' VBA does not provide comfortable functions to delete files, so we use
' VB-Script.
Set objFSO = CreateObject("Scripting.FileSystemObject")
' Delete all files in the SecureTempFolder (True = force deleting)
Call objFSO.DeleteFile(strOLK & "*.*", True)
' Reference the SecureTempFolder
Set objFolder = objFSO.GetFolder(strOLK)
' Open the folder if it is not empty
If objFolder.Files.Count Then Call Shell("explorer.exe " & strOLK)
' Clean Up
Set objFolder = Nothing
Set objFSO = Nothing
Set objWsh = Nothing
